S5 Volume Bar
Richp
S5 Volume Bar
Hi
I recently had to reinstall my S5M laptop, as i had a virus i was unable to remove, since reinstalling the laptop is fine however my volume bar does not show any more wnen i use the fn button and F3 or F$ to increase or decrease the volume, also when i press the muting key the words dont appear on the screen either, can anyone tell me how to get these back on?
thanks
Thalamus.
Champion
Hi Richp,
Welcome to Club vaio, :slight_smile:
Rich912 posted a similar solution to your problem in this thread
ant1uk
Hi welcome to club vaio
I had the same problem when i had a virus i reinstalled everything and one of the Volume keys and Fn key didnt work.
It was very strange, i did a install again and it was fine.
I think i know why i adjusted the volume as i was restoring it which may be the cause.
Richp
thanks for your help, i have tried following the thread and the information but nothing as yet, ill keep trying... i cant seen to find the utils exe prob although i have downloaded the utils folder
Rich
