Screen Issues
apierc1
Screen Issues
Alas dear Club Vaioers, I have come across another problem with my Vaio :slight_frown: I noticed last night while watching my new American Dad dvd that along the bottom about where the top of the task bar should be, a whiteish line, now when the task bar is visible, or when it is completely black or many colours, the line isn't visible, but with clear monotonal colours the line is visible. At first I thought it might have been a problem with the dvd, but it appears that after applying a light brown wallpaper and hiding the taskbar, there is the line, I have reported this to e-support, is it common? will ony replace my screen? it stretches a bout 2 inches from the roght hand side in, :slight_frown:
Andy
4 REPLIES 4
apierc1
1. I think I have so many views because i installed latest skype and my IE7 went crazy opening loads of new tabs and windows.
2. As LCDs unlike CRT's should get screen stained, does this mean I have a row of dead pixels?
Many niceties
Andy
apierc1
:slight_frown:
apierc1
:cry:
kee-lo_
What can we say Andy? Except contact VAIO - Link for a repair
