Serial number etc on PCG-K415S???
pculbert
Hope someone can help. I'm trying to download the original drivers and utilities from the download section of the sony support section. Before I can do so I must enter the product key and serial number which are supposed to be shown under the notebook. I cant find any number that remotely looks like the sample numbers on the site. All I can find is a "Service TAG" barcode and number.
Am I looking in the wrong place? :slight_frown:
Thanks in advance for any help.
Padraig
Hi Padraig,
All serial numbers have 15 digits, split up in an 8-digit model code beginning with 28 and a 7-digit unit code.
Depending on your model, you can also find the number in Control Panel -> Vaio Control Centre and look in System Information.
:wink:
