Serious Problem With Battery
nickorfas
I have bought a vgn-fz19vn for only a month and i have a serious problem with the battery.When i haven't turned it on for 4-5 days ths battery level is approaching the 30%.The last time i had used it,it was fully charged.I don't think that it's nornal.Is it?
If this is the case then contact Sony and they will replace the battery if it is defective.
First, check that your Vaio is fully shutting down - the default when clicking on the screen button with the Power symbol in Vista is "Standby" (Sleep) not "Shut Down". This would explain your problem.
:wink:
