Should be a quick question!!!
tash_edwards89
Does anyone know which drivers the FN keys and the S Buttons come under please.
Thank you in advance
Tash
Resonate
Tash
To get your FN & S Buttons to work you need to Download the Sony Pre-installed Utilities from VAIO Support
Create a Folder to store in & then in order for the function keys to work,
you will need to install these installers from the Utilities in the correct order:
1 Sony Utilities (folder 1)
2 Sony Shared Library (folder 2)
& finally
3 Vaio Event Service
:wink:
