Skype Video Control Screen
Ziegenhorn
The Vaio VGN-FE11M comes with a built in Camera and Skype Software, which is great. Unfortunately the control screen window within Skype does not work on the Vaio (the window is still). This is definetely a video driver probnlem, as it works on other Notebooks I use.
Anyone have the same problem?
4 REPLIES 4
timurvanbeek
Hi, yes got the same problem, Although I have a Vaio FE11S..
A Solution would be great!
rich912
Hi and welcome to Club Vaio.
This could possibly be a result of your power management setting. Set the CPU to 'performance' and see whether that makes a difference.
Go n-éirí an bóthar leat
timurvanbeek
Hi Rich,
Thanks for your suggestion, unfortunately, no good, my processor is already on 'Performance'...
Got any other ideas?
Much appreciated :smileygrin:
Thanks,
Timur
rich912
Hi Timur,
Sorry, I am now at a loss as what to suggest. I have a feeling that this is a power management problem rather than driver, but I may be proved wrong on this. Some notebooks have an option setting of SPEED and STAMINA, if you have this option try STAMINA.
