sm bus controler problem
adams392
Hi,just reinstal my sony vaio us version sve1511cfxs and in device manager is writting sm bus controler
drivers are not installed.I did try severals times to reinstall and download drivers from sony web page suit to my model and is still same problem Is any body what can help me?please!
rich912
Hi adams392,
Have you recovered the machine using the Vaio recovery media? If so all necessary drivers should have installed.
If you have installed a retail copy of Windows have you installed the Chipset drivers? These are available from the US support site – listed under Motherboard.
http://esupport.sony.com/US/p/model-home.pl?mdl=SVE1511CFXS&template_id=1&region_id=1&tab=download#/...
Close all open applications prior to installing the driver.
Rich
Go n-éirí an bóthar leat
adams392
Hi Rich
Thanks for answer
I didnt recover machine,becouse buoght laptop second hand and previous owner did install Windows7 Ultimate with no activation key so I had to reinstall back to  original Windows7 Home Premium what was inside before I did download all drivers direct from sony and installed Chipset drivers basically everything what had to be and always same problem flashing sm bus controler
Dont know what to do else
rich912
Hi adams392,
I’m not sure what the problems is but suggest you try the Intel Driver Update Utility and chose the option to “Automatically scan your system for up-to-date drivers and install them quickly”
http://downloadcenter.intel.com/default.aspx
Rich
