Hi
I just purchased a Sony VAIO laptop VGN-FS415M a couple of weeks ago, i have recently noticed that small bubbles are popping out on the LCD screen(as if the coating on it is coming out).If i wipe the bubble by applying a little pressure the spot tends to disappear.But other spots are appearing in other areas of the screen
Could you anyone please tell me if they have faced the same problem before and also how to resolve it once and for all
Hi
Dear Thalamus
Thanks for the immediate reply
Could you please clarify if the LCD repair is also covered under the warranty?
deepak
Should be, this sounds like an extreme problem
Dear Thalamus
