Some more V3 firmware deficiencies.
moreauan
A few more things to fix for the next update:
When charging, the charging icon is microscopic. I think they used the same bitmap as the remote. There is so much room on the screen, and a 3-pixel high icon is used!! This should be revised in the next version to make it visible from at least a metre away like in the previous (factory) version. And no, I'm not blind - I have 20-20 vision and don't require visual aids.
Also, the remote display indication is painfully slow. The song/artist displays for the first 30 seconds or so, and then reverts to the dopey clock/date. Pressing Back does recall the song/artist name, with a huge delay. This was all working fine in the previous (factory) version.
0 REPLIES 0
