sony sve1512m1ew cpu upgrade
wayne0909
Sony sve1512m1ew laptop
Hello my question is can I upgrade the cpu in my laptop sve1512m1ew
Hi wayne0909 and welcome.
In theory you can upgrade to any Ivy-Bridge processor that fits into a G2 socket but to make any appreciable gain, you would have to move to an i7 quad core processor which would roughly double the CPU performance.
However, this would likely consume about 40% more power and cause overheating problems.  Overheating tolerances in Vaios are not great and your model was designed around the Intel Core i5-3210M it was sold with.
Also, it makes no financial sense as an Intel Core i7-3630QM quad core processor would cost £250 and only give the same integrated HD4000 graphics as you have now.
Probably the best thing you can do is max out the RAM by increasing it to 8GB and sticking with the existing processor.
:wink:
:wink:
