Sony Vaio ATI Drivers
Aceguitarist
I have an E Series Sony Vaio, with an ATI HD Radeon 5650 graphics card. I was interested in getting the latest drivers and so looked on the ATI website, then I found out you have to get them from sony - fair enough. But the latest drivers for the graphics card on the sony website are from 2010? This means they are not allot of use and they are the same as my current ones. Any ideas how I can get the latest drivers for my Vaio laptop?
Many Thanks,
Ace.
Hi Aceguitarist.
All you can do is contact Vaio Support and list for them what is not working properly with the current driver.
There are new drivers every other week but most will not affect your Vaio.  Sony will only update drivers if there is a known problem - they probably will not know unless you report the fault.
You can try Googling for "mobility modder" but I don't think your OS/ATI chip are supported.
:thinking:
