sony vaio fw21e blueray player not working ?
johno4779
Hi can anyone help me out i have this sony vaio vgn fw21e laptop which is is around five years old but has had very little use,i have recently tried to watch a blueray movie but had not joy it just kept on rejecting the disc but it will play normal dvds, but there are two lasers on the discdrive now is it the case of buying a new discdrive or is there a simple fix?please can anyone help thanks
rich912
Hi johno4779,
There is rarely a simple fix for this problem.
You could try cleaning the laser lens with a proprietary cleaner and also clean the Blueray disk. There is also an update for WinDVD BD available from the support site - worth installing assuming you have not done so already.
http://www.sony.co.uk/support/en/product/VGN-FW21E/updates
Rich
Go n-éirí an bóthar leat
Hi johno4779 and welcome.
When did it last playBDs?  What version of WinDVD BD are you trying to use?  I think Version 8.8.0.282 is the latest for your model - have you got this version installed.  It needs updating regularly to keep up to date with the latest encryption.
Is it a recent release of BD you are trying to play?  Have you tried other discs?
Before replacing the drive, check it is not the software by downloading the free trial version of PowerDVD 12 and see if that works: -
http://www.cyberlink.com/downloads/trials/powerdvd/requirements-xp_en_US.html
or install a free DVD/BD Player like DAPlayer and try that.
http://www.digiarty.com
If all of that fails, then think about replacing the drive.
:thinking:
