Sony vaio laptop battery replacement for SVE151J13M?
hellsbells74
Hi does anyone know where I can get a genuine battery for my Sony Vaio laptop model SVE151J13M?  I've not had any luck with ebay.  Thanks
A search on Google for ‘Original Sony VGP-BPS26’ brings up a few hits at about £60.
You could also try searching using the correct Vaio name used for all support issues which is SVE1513B1E.
These are getting difficult to find!
profile.country.IE.title
d11a4a25t3c50e94
detail how to work above
