sony vaio VPCEB3F4E laptop help
wosoft
Hello every one
i nned help about sony vaio VPCEB3F4E model
Me purchase this laptop from market in used condition
1st me not find this laptop webcam driver.
Driver download link
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VPCEB3F4E
Me download all driver but me not find any webcam driver 2nd PCI simple communication driver 3rd Unknown
plz help me about this prblm
one more question about this laptop
how can i check this laptop original sony product
tell me method how can i check this laptop original or not
The webcam does not have it's own driver - it is a Universal Video Class USB device and works with any Version of Windows using generic drivers within Windows.  The webcam should work automatically and just needs registration with Skype or any IM program.
Try entering the Serial Number of your Vaio into the Support website here: -
http://support.vaio.sony.eu/computing/vaio/index.aspx?m=0&l=en_GB
Check that the Serial Number is accepted and check that the correct model comes up.  You can find the Serial number on the bottom of the Vaio or in Control Panel -> Vaio Control Centre.
You can also try registering your Vaio online
:wink:
