Sony Vaio VPCEE2M1E Laptop power light
rainy_h
The light on the power button is staying on after shut down.
Anyone have ideas why?
2 ACCEPTED SOLUTIONS
I think this must be a fault - the light should turn off when the Vaio is shut down of placed into Hibernate.  It blinks orange in Sleep mode.
If it is green when shut down, I would contact Sony Support.
:wink:
rainy_h
Yeah, got told by Sony to shut down, unplug from mains, remove battery, put battery back in and turn on.
It worked. Hope it works for you.
5 REPLIES 5
:wink:
rainy_h
Thanks, will do.
22dlewis
Hi mate,
Did you find out if this was a fault as I have a week old Vaio which is doing the same thing?
Dan
rainy_h
daveyah2002
Late post but it might help others.
The Battery removal works but the problem I found caused it was that Outlook hadn't shut down properly. ....waitng for programme to close still going when when PC shut down - still there when restarted. So PC not properly shut down.
