Sony Vaio VPCEL2S1E motherboard question (supported cpus)
profile.country.el_GR.title
kostaks3
I have a sony vaio VPCEL2S1E and in future i plan to change the cpu.
I tried to find my motherboard specifications to see the supported cpus but i couldnt find which motherboard i have.
So,does someone know which motherboard i have or how i can find it or even the supported cpus for this.
Thanks for your time!!!
Message was edited by: kostaks3
6 REPLIES 6
Hi kostaks3 and welcome.
This model has a AMD Dual-Core E-450 APU so I guess any 40nm "Brazos" series processor should fit in the Socket FT1 ( BGA-413).
http://www.notebookcheck.net/AMD-E-Series-E-450-Notebook-Processor.60138.0.html
The CPU includes the AMD Radeon™ HD 6320 Graphics so you will have to take that into account.  At the moment your E-450 is the top-of-the-range for this mobile socket so I don't think an upgrade is available to you.
Most Vaios have a Sony custom motherboard but I'm not sure if this is the case with the AMD models.
:thinking:
kostaks3
You mean that this is the best cpu for my laptop?
And i need to change the graphics card with the cpu?
I know that in laptops things are very complicated but give me your lights
flogger12345
For laptops, most graphics are preshared with the main memory(RAM). I guess the best option here is to find the best RAM module with shared graphics on it. http://imagicon.info/cat/12-13/vbulletin-smile.gif
Hi kostaks3,
Yes.  There does not seem to be any better CPU than the E-450 that will fit your motherboard.  The E-450 APU was only released 4 months ago and is the most powerful available.
The APU combines the CPU and the GPU on a single die so you have to change both together (like available on the latest i3, i5 & i7 CPUs from Intel).
Quite honestly, there is nothing worth upgrading on this model.  You could add an extra 4GB of RAM - giving you a total of 8GB - but this may not give any noticeable speed increase as the limiting factor will always be the processor which is OK for everyday computing but not for anything too demanding.
:thinking:
As usual, I have no idea what you are talking about - do you?
:thinking:
rich912
I assume that flogger12345 is refering to the new RAM modules as marketed by the inventor or the reusable envelope:smileywink:
Go n-éirí an bóthar leat
