I recently bought a vaio VGN-FE21B and I'm really pleased with it except that every so often, when I am sufing, I get jumped back a page, or if I am editing a word document or excel spreadsheet it will jump me up a few lines. I think this is something to do with the mouse. Has anyone else experienced this? Thanks. EmmaLouise
Hi EmmaLouise and welcome to Club Vaio.
Are you referring to the inbuilt touchpad or a USB mouse?
There are a few things that you need to check:
1 Does Device Manager recognize that you have a Pointing Device or does it report a PS/2 Mouse?
2 If a Pointing Device is correctly reported then possibly you need to alter the sensitivity of the pad as you could be inadvertently touching this as you type– ether Control panel > Mouse, or of you have an icon in the system tray double click this. Also check out which tap functions are enabled.
3 If Device Manager reports a PS/2 mouse then you need delete this and reboot – hopefully Windows will then recognize the pointing device and install the correct driver (if not then let us know as there are further procedures that will work).
4 If however you are using a USB optical mouse then make sure that your mouse pad is not multi coloured (try a plain sheet of white paper) as this can cause problems.
Hi
i happened to be having a problem with my USB Optival mouse jumping around the screen sometimes. probably it was because of the multi-coloured mouse-pad.
thanks for the tip.
cheers,
Mel
