Support page for my 6 months Vaio SVE1713M1EB closed ?
profile.country.GR.title
siegmund10
To my surprise I found out that the support page for my Vaio SVE1713M1EB exists no more only a few hours ago !
In fact it has been replaced by the following link which as you can see doesn't contain my exact model as before !
http://www.sony.co.uk/search?query=SVE1713M1EB&locale=en_GB
Any suggestions on which of the 3 models of the above link shall I use for my updates and support ?
Thanks in advance !
rich912
Hi Siegmund10,
I have received confirmation that SVE1713M1E is the correct model and the B suffix is just a chassis colour.
Rich
Go n-éirí an bóthar leat
6 REPLIES 6
rich912
Hi siegmund10,
It will be the SVE1713M1E as the suffix /B is just a chassis colour reference.
Rich
siegmund10
Thanks for your reply, however are you sure I can install anything from there without problem ?
I'm asking because I've seen a newer model SVE1713M1E (without B) having the finger swipe charm feature while mine hasn't.
A reply to that would be highly appreciated !
Thanks again !
rich912
Hi siegmund10,
I am almost certain that this is the same model but in order to be 100% certain I have asked for confirmation from a Sony contact. It may take a few days to receive confirmation.
Rich
rich912
Hi Siegmund10,
Rich
siegmund10
I simply can't find words to thank you !!!
rich912
You're welcome siegmund10 :slight_smile:
Rich
