SVD1322Z9EB - ethernet port - where is it???
1eyedjack
I need to be able to create a wired connection to my router, but I can't find the ethernet port on the computer.  Seems such a ridiculous thing to have to come to the forums to ask.  Can't believe that they would build one without such a port.  What am I missing, please?
rich912
Hi 1eyedjack,
No you’re not missing anything – there isn’t one. A  Wireless Ethernet mini router should have come bundled but this is of no help if you definitely need a wired connection.  A USB to Ethernet adaptor may be the answer – they are relatively cheap.
Rich
Go n-éirí an bóthar leat
