System Clock
chrislynch
System Clock
Hi, Ever since my Vaiowas repaired for the second time in a row the clock is not keeping time, if I shut down the computer and restart it again the clock and date will be the same as when I shut it down.
Has this happened to anyone else and if so has anyone got a solution for it cheers......
6 REPLIES 6
kee-lo_
You need a new CMOS battery.
chrislynch
How do I find out what type (model/voltage) I need? Are they easy to replace in notebooks?
chrislynch
And I only Have the laptop for 13months the CMOS should not be dying alreay correct?
Thalamus.
Champion
Did sony repair your Vaio, if so you could contact them for the correct CMOS battery.. :thinking:
chrislynch
Ya they did, twice in a month, they didn't do it right first time. Its not in warrenty anymore so will they send one ot???? :thinking:
robpaxton
It's strange that the clock just stops and doesn't reset to a default. It could be that the real time clock is faulty.
I would contact Sony support as there is a warranty period on the repairs.
