I notice from using CPU-Z that the 1GB of RAM in my VAIO SZ is running at a 5:8 divider with the FSB, this means the RAM is running at 533MHz, but since the bus is running at 667Mhz I'd like to have my RAM running in sync with that.
That being the case would the VAIO detect 667MHz DDR2 RAM and run it at 667MHz or would it just run it at 533MHz like the original RAM?
Also, any idea if it would increase the amount of memory the Turbocache on the GeForce 7400 would use?
Thanks in advance!
