I have just taken delivery of an SZ61MN and have downloaded all the drivers and utilities for XP.
I loaded XP Pro and went through all the drivers and utils but cannot see the camera in Device settings, therefore apps don't see it either.
Is there a trick to get it working under XP?
Regards,
Jeff
At last, found the correct instructions. For others that have the same issue, here they are:
1. Go to Device Manager, USB devices
2. Expand the USB list
3. Find the item marked "USB Composite Device" and right click it
4. Select Update driver
5. At the wizard, select No, not at this time, click next
6. Select Install from list or specific location, click next
7. Select Don't search I will choose driver to install, click next
8. Click on have disk
9. Browse to folder where the driver is and open the Camera_Driver folder
10. Click finish when done.
Hope this helps
Jeff
Thanks for posting that solution Jeff.
Oh - and welcome to Club Vaio!!!
