T2XP - bit loose top of screen
nethawk
I found that the part in the top of the screen, in the center, is a bit loose. It's loose too in yours? I think that its to put the privacy filter but im not sure at all! thank you!
http://img176.echo.cx/my.php?image=loosee9xh.jpg
the red area
Twisted-Rizla
Hi Nethawk
Welcome to the forum:smileygrin:
It shouldn't be loose. If you are concerned give Sony a call. Telephone numbers here
lyapple
It's not loose on mine. I have however managed to get the cable jammed in the LAN connector.
