tap 20 brightness
lex20000
tap 20 brightness
hello All,
since i updated my tap 20 to windows 8.1 the screen dimming function does not seem to work via manual or auto.
any ideas what i can do to put it right?
thanks in advance
rich912
Hi lex20000,
This is a common problem with various Vaio models after upgrade and Sony is aware – there is currently no fix. From the Sony Windows 8.1 install guidance….
“Fn+F5/F6 does not work. Please use the Settings charm to change the brightness level.”
Although your model is not listed my guess is that it applies.
http://www.sony.co.uk/support/en/topics/landing/windows8-1_upgrade
Rich
Go n-éirí an bóthar leat
