troubels with keyboard pcv-w1
robje
I have troubels to setup the way the keyboard of my pcv-w1 types. Anybody knows how to handle this problem?
robpaxton
If you mean you want to change the keyboard layout then:
In the Windows XP standard Start menu, click [Start] , and then click [Control Panel] .
In the Windows XP classic Start menu, click [Start] , click [Settings] , and then click [Control Panel] .
Double-click [Regional and Language Options] .
Click the [Languages] tab, and then click [Details] under "Text Services and Input Languages".
Click [ADD] under "Installed Services", and then click the language you want to add and the keyboard layout you want to use for that language.
robje
Thanks! this solves the problem! much better this way!
