Hi Everybody !!
I have a vaio pcg grt915M and i can t watch movies on my tv.
my nvidia driver is 4.6.9.0
If i look in the properties, there's nothing about TV ?
if somebody have an idea ??
thanks for your help :smileygrin:
Definately a driver issue then.
Make sure you have the original driver from the CD installed.
i installed tvtool 9.7 for nvidia and now the cable is detected.
But now nothing happen if i use the hotkeys for choosing my screen : I can choose tv+lcd but after if i see Audio Video on Tv nothig appear.
Maybe there's a problem on tv card ?
Does it work with another TV?
I don t have another tv.
But i don t understand why it doesn't work.
my tv is 2 years old.it's a 23" 16/9 flat tv
If it can makes you to feel better I have the same problem with same model of VAIO laptop (GRT 915M). I have never realy tried to risolve it, but using the last update of drivers (Version 4.6.9.0) I have only got a bit of problem with another hardware.:smileysad:
i think the better thing i have to do is to return it to sony. hoping they will be able to do something.
