Turn off screen on downgraded vaio
mlkwestcoast
hello
i got a vaio fz11m wich i downgraded from vista to xp, it was very hard, but i got 95% of capabilities to work, when i downgraded i used vaio power management of vaio fe31M wich is very similar to fz11m, the application works great exept for turning off the screen after a certain wait time that we can configure in windows properties, when i configure it for example for 1 minute (only the screen) its turn off after that delay, but when i restart the laptop this value is not saved, so i have to put it each time.
so iwant to know if there is a solution to fix that , or maybe if its possible to create a shortcut to turn screen of immediately (while letting the pc working, just the screen off)
thanks
0 REPLIES 0
