Call me stupid :smileygrin: ...but how do you use the TV out on the back of the Vaio A215Z?
The TV-out hole does not look like a standard cable connection. Am I wrong? Is there a special cable I have to buy or do I have to buy that docking station and lug it around when ever I want to connect to a TV?
Thanx in advance!
You need the Sony VMC20FR AV Cable
Many thanks for the quick reply
No problem.
You dont need a sony cable, unless you want to be ripped off. You just need a standard triple pole minijack to 3 phono camcorder cable, they are available on ebay for about £5 with P&P. If the audio and video dont match up right, just change the phono plugs round into different sockets until you get video and sound, job done! and its much cheaper than the sony way.
True, just couldn't think of the name of that jack thingy LOL
