TV Tuner for PCV-RZ502P .... need one.... can anyone help me please?
Spectre
As well as the computer above I have a flat screen LCD monitor type SDM-HS94PS....the whole set-up is crying out for a decent TV tuner (preferably digital for freeview channels). I'd like to be able to record programmes too and save to hard disc. Don't mind whether its internal or external as long as its good quality reception and function. Must be analogue reception and fairly sensitive - as signal is not too strong. I have looked but I can't find anything that looks suitable.
I have high hopes that someone out there can suggest something.!grin.gif|___jive_emoticon_name=grin|jivemacro=emoticon|class=jive_macro jive_emote|src=grin.gif! By the way I'm in UK.
kee-lo_
Internal is the best as you'll get no lag
Spectre
Thanks for the reply....very helpful....I was thinking that might be the way to go if there were no dedicated sony products. :slight_smile:
kee-lo_
No problem
