TV Tuner - Pal 60 (60Hz dislay)
tjgibbins
hi there i currently have a Bravia KDL-32wd603 tv. it doesnt have AV support on it so i cant play my retro games consoles on it. i have recently bought a AV to HDMI convertor to play the games but some of the games requier 60hz which makes the screen jump around, it works fine at 50hz but i think this is because i live in eroupe.
Mick_D
Moderator
Hi & welcome to the Sony Community :slight_smile:
Your TV should be able to deal with either 50 or 60Hz inputs, so any issue you have with flickering will not be down to the TV itself. As you say, some games do require a specific screen frequency more suited to displays in the US, where 60Hz is the default, and I suspect they may not be compatible with your European TV.
Sorry I can't be of any further help.
Mick
