tvtv records an hour early. can any one help me thanks for any help. i have just paid for a subscription and it dousnt work
Hmm
*fires up IE to check VL for the RA104*
tvtv
Version : 1.0.0.642 Size : 1.45 MB
Is this the one you have?
yep thats the one mate.
Same problem with the RA then
Suprised really, tvtv sent me an e-mail last October when the times changed because of the bug then.
You can see why their customers are rather annoyed around now!
i got an RA304 and i have newest version, 1.0.0.658
my pc came with it. This problem occurs because the pc automatically adjusts when the time changes an hour forward or back, but somehow does not register with tvtv.
trust even the latest version does not cure this annoying bug.
this is what tvtv told me when i emailed them.
Dear Sir,
you can find the update on the following website: www.vaio-link.com.
Please visit the download section corresponding to your Vaio model.
Best Regards,
your TVTV Support
i told them the version of tvtv i was using.
and the only update on vaio link is the one im using.
so they dont even read the emails
useless
i emailed them 'in disgust' and they told me that even the latest update does not fix the problem and they promised an update which did within 2 weeks at the latest.
hope they get it fixed soon and stick to their word
there you go, all we can do is wait now
This is why I don't subscribe, the money's not being used correctly, so I use the good old RT
has any one Heard anything new. about this problem
nope, but they promised an update soon, however i would not get your hopes up as this bug keeps happening
