Unable to get my laptop to work
nik2004
I was using my laptop this morning.....had to got out & forgot to shut it down. On my return 2 hours later it was turned off as the battery had run out ( It wasn't oplugged into the mains ) I connected it to the mains to recharge the battery....laptop went on to the page I had left it at earlier, then it shut it's self off. I turned it back on again...the Vaio logo came up then the dots going in a circle....after that the screen went black again, I just can't get it to come on. I've tried re-booting it, tried the assist button, tried F10....nothing seems to work. Any help or ideas gratefully received....Thank you
sgdavies
Hi there,
have you tried a  "Hard Boot?, by this I mean holding down the Power button for about 5-8 seconds, try this when the Power is plugged into it, also try to verify there all leads are connected proberley and secured, especially from laptop to powersupply. also verify the plug socket works ok, and is switched on. you might also need to check the fuse is ok in the plug.
