Uninstalling Vista
tman16
Uninstalling Vista
I am jsut about to upgrade to Vista, in case i wanted to revert back to XP how would i be able to do this as i never got an XP disc with the laptop?
Erec
hi
I think it´s very difficult to go back to Win xp because you should had made a recouvery disk with the Vaio software.
Thalamus.
Champion
Hi Tman,
Your Vaio may have a hidden recovery partition, if so you can create a set of recovery disc's by following this guide .. :slight_smile:
