Hi guys... I made a big mistake, I erased the partition on the hard-disk with the drivers and applications and now that I've formatted the pc I can't use my tv-tuner. I tried a lot of driver and it doesn't work with anyone of them. Could anyone tell me where i can find the tv-tuner driver for V2S? The sony mpeg2-ts splitter doesn't work.
Thanks in advance...
up.
Help me pls
Hi nightflier,
Have you downloaded and installed the Preinstalled Drivers and Preinstalled Utilities from VAIO-LINK ?
I did,but Zone says that "the TV or the screen is used by another program, or i have to change my visual settings", maybe that depends on the graphic video card drivers ? Where i can get the right drivers for GeForce FX Go5700 on V2S ?:smileyconfused:
up
I don’t have this application but sound without picture suggests that you are missing a codec, possibly DivX
