Upgrade memory sz1xp
Pingu1
Hello,
I want to upgrade the RAM of my sz1xp to 2g. But I have a pair of doubts before:
1) Acording to support site the new memory module to upgrade has to be DDR2 667 SDRAM:
http://support.vaio.sony.co.uk/accessories/compat/compat.asp?site=voe_en_GB_cons&m=2160&c=10
But the memory module which has now installed is DDR2 533 SDRAM. I don't undestand this speed discrepancy.
2) When I had 2 memory modules of 1g each one, will they work in dual channel mode? Will I feel better performance with dual channel?
Thanks in advance.
Regards.
hi, i´m also a sz1xp/c owner, and i upgraded to 2Gb, i can not be specific but i can feel the great diference with the upgrade.
About your questions i found in the internet:
1) "memory was designed to be backward compatible so generally speaking, you can safely add faster memory to your computer." that´s why sony sells the DDR2 667
2) i don´t know about that, but if it does, It seems you get better perfomance: "http://en.wikipedia.org/wiki/Dual-channel_architecture"
i also had many questions when upgrading if you want, send me a private (pm) and i tell you where i bouth the memory...
bye :slight_smile:
Rik_P
I have a VGN-FE21B and I Upgrade the memory for 2048 @ 667 but it works only at 533 because the Bios :thinking:
The SZ1 -Series will support either PC2 4200 or PC2 5300 memory.
If you mix memory it will work at the speed of the slowest module.
The SX1-Series does not support dual-channel operation.
Have a look here CRUCIAL.COM
:wink:
