Upgrade to Windows 7, Bluetooth problem
vicholde
I upgraded from preinstalled vista to windows 7, but now my bluetooth wont work, before i had a preinstalled toshiba bluetooth stack, but there's none of it now :slight_frown: help?
As Sony do not support Windows 7 on your model, you will need to reinstall the Vista drivers and utility for bluetooth.
You can download the Originally Installed drivers and utilities and any Updates for your model from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-C2S_G
:wink:
What model do you have?
Can you confirm if you carried out a clean install of the full version of Windows 7 or did you use an UPGRADE DISC?
:thinking:
vicholde
It is VGN-C2S
I tried to do an upgrade, but it wouldnt work, so I had to do a clean install.
:wink:
