Hi all,
I have a vaio vgn-a417m with 512 ram but i wanna put 1024 in ive been on club vaio and selected the upgrade memory tab and i says to undo some screws take out keyboard an insert new card but my 512ram is actually 2x 256 cards but when i had a look and on the pics on the step by guide it shows one card where is the other one?
because i take it i will need to take out the two 256 cards and replace them with two 512 cards?
any help on how to change them would be great
thank you:smileyhappy:
Hi boywonder,
One memory module comes out of the bottom of your A-Series. It is behind the cover held by one screw in the centre of your Vaio.
The other is below the keyboard as you say.
Have a look at Page 157 of your USER MANUAL (this .pdf file may take a while to download).
