Hi
HELP!!! I have installed XP SP2 and cannot get my any of my USB controllers to be recognised as USB 2.0 - all operate as USB 1.0. I have looked everywhere to get updated drivers but cannot get any. Any Idea's? Help would be gratefully appreciated.
Have you downloaded and installed all of the updates from http://www.vaio-link.com ?
Also try windows update to see if updated drivers are offered there.
Thanks for the reply - yes I have been to both vaio-link and Windows update and have updated everything possible but still with no luck.
Any other idea's?
Have you triend uninstalling the hub? This usually refreshed the drivers.
Yes - have tried unistalling the hub but again, still re-installs them as usb1.
