I HAVE VGN-N11M/W CAN ANY ONE HELP ME HOW TO INSTALL USB 2.0 AS IT IS NOT AVILABLE IN MY COMPUTER
Hi vikasva.
Your N11 Vaio should have USB 2.0 installed as standard.
Go to Device Manager and expand 'Universal Serial Bus Controllers'. Do you have a "USB2 ENHANCED" controller installed?
Also make sure you use a new USB Cable - some older ones only support USB 1.0.
hi blencogo
when i attach my camcorder to laptop my camcorder does not go on USB mode it did not happened before
