Hello from belgium
i ve a FE21H
Problems with usb speaker
try to install altec lansing xt1: cd asked
try to install logitech v20: cd asked
No installation cd necessary from logitech and altec.
The altec are installed with no problem on a macbook and desktop (HP, acer, oem...)
The vaio e-support can't give a solution.
Vaio= great display but ... bad sound ????
mm28 with minijack is my solution
