USB DVB Box Help
induct
USB DVB Box Help
I'm currently looking for a USB digital tv tuner. I also want to use it as a video recorder to capture some old family videos and stick them onto DVD. I'm currently looking at this one:
Hauppauge Digital DEC2000-T
Have you lot got any suggestions?
11 REPLIES 11
Psaila
Oh An easy one here ...........
Sony VTX-D800 This works very well for me , I would think it would sit very nicely next to any PC . But A VAIO well , its made for the task ...." Five Star * * * * *" I rate This Item , many months of happy use , in the past .
Why use your usb when other stunning options are open to you ?
induct
Cheers Psaila
One thing, it won't connect to my Vaio, thats what the usb is for.
induct
Ah, is smartlink the same as firewire I-S400?
Psaila
And I think that means you leave one more usb free ... cool or what .... he he he
Happy New Year ...
robpaxton
Hauppage gear is normally pretty good, the only other one I've found is http://myahead.com/go/look/product.show_product?v_id=8528
Smartlink isn't a PC interface . . . . it's for connecting to TVs and Video recorders and has (I think) something to do with autosetup.
Psaila
Many thanks Rob , theres one I had not seen .
Why are there so many problems linking Sony product's , I'm a loss at the problems encoutered by so many trusting Sony User's Who buy Sony products, that you would feel would link to each other with out a second thought , What Happend SONY ?
robpaxton
No problem Raymond, I wouldn't normally have butted in but I wouldn't have liked Induct to have bought the Sony box only to discover that Smartlink isn't a PC interface . . .
Psaila
Thanks Rob , I seem to forget that other can't do as I can with my PCV-PW1 , I would feel really bad if someone spent hard earned funds only to find it failed, Thanks again Rob .
TIME FOR THIS OLD MAN TO RETIRE I FEEL .
robpaxton
We all make mistakes . . . . retirement isn't the solution. You have lots of friends on the board (me amongst them I hope) and we enjoy hearing from you.
