Vaio battery charging problem
Boris999
For about two weeks I was experiencing problems with charging battery on my Sony Vaio PCG-Z1XMP.
The system tray battery indicator kept constantly changing between charging / not charging. About every 30 seconds. Recently the icon settled at charging, but the battery level stays at 0% and won't go up.
Battery Characteristics from PowerPanel:
Manufacturer: Sony Corp.
Battery Name: PCGA-BP2V
Chemistry: Li-ion
Charge Cycles: 362
Remaining Capacity: 0.00 Wh
Full Charge Capacity: 37.65 Wh
Design Capacity: 48.84
Please advise whether the problem is with the battery, power supply or anything else.
Many thanks
Boris
20 REPLIES 20
lieven
Have you tried removing the battery and running on AC power only? This should work, if not I would suspect that your AC adaptor is faulty.
Hi Rich,
I've tried to run it without the battery, but it does't work.
The power led lights up for a millisecond and that's all.
Ive been thinking of a faulty charger.
But the thing is that charger LED does bun and that it sometimes does charge (for a couple of seconds or so) and then doesn't.
Most of the time when a charger is broken, it doesn't do a thing.
Perhaps I should try to see if I can find another charger to test it with.
lieven
There is one weird thing though.
The battery charger doesn't warm up at all.
I hope you're right about this Rich.
Boris999
I have reinstalled utils.exe. Unfortunately, no difference.
carthorian
I suspect a malfunction in your charger. If still under waranty, call the hotline and they shoot provide you with a new one for free.
lieven
I've just bought a new ac adapter on Ebay (hope to receive it next week), so we'll see.
Unfortunately, the laptop is out of warranty.
rich912
Fingers crossed for you lieven:smileygood_luck:
Go n-éirí an bóthar leat
lieven
Today I received my new battery charger and guess what.
It works!
Now I can finally turn on the laptop with only the charger connected and the battery charges without interuption.
Thanks for the tips and support u guys!
Now I can truly say I'm a happy Vaio user and close the case at E-support. :smileygrin:
Boris999
I bought a new charger which appears to have solved the problems.
Thanks for all the useful replies to this post.
rich912
Pleased to hear of the successful outcome for both of you:smileyhappy:
Hello Sony
How are You?
What's wrong is that my charger keeps making a beep sound and whilst its doing that i can't charge my PC and after it takes longer for my PC to charge.
Please Help Me
Regards
Ismail Kalam
