VAIO Camera vs Windows 7
profile.country.pt_PT.title
mariafgv
Hello there!
So I have a VAIO, model VGN-FZ21E, which I had it formatted and installed Windows 7. I had the Windows Vista before.
Serie nr: 28209564 5001045
With Windows 7, the system doesn't recognize the videocamera.
Does anyone know or have the driver for my laptop? The camera is Motion Eye.
Thank you so much!
V57...
Hi mariafgv,
Wecome to the Sony forum...
Install Vaio Camera Capture Utility, (Original Utilities Package...decompress with 7Zip, WinZip or Winrar)  and install in compatibility mode with Windows Vista...
Then, install the driver,,,Original Drivers Package...
Regards
V57...
Hi mariafgv,
Regards
mariafgv
Thank you so much V57 :slight_smile:
It worked and I have my camera back, thank you once again!
V57...
You're very welcome mariafgv - pleased to hear that it worked...:smileyhappy:
Kind regards
