Vaio-link drivers appear & disappear...
Pingu1
Hello,
Anybody knows why in vaio-link webpage the drivers/applications appear and after few days this driver/application disappear?
For example for SZ1/XP model: wlan driver version 10.5.1.57. Or for example last week publicized the new version of the wireless switcher application, and now is not any more.
Thx in advance.
Thalamus.
Champion
Hi Pingu1,
Perhaps Sony have discovered a problem with the update and have removed it temporarily... :thinking:
Pingu1
Ups, thanks Thalamus for your response, I hadn't seen it.
Yes but, I believe that the least Sony can do is to explain the reasons to remove these drivers & applications. At the moment, I have installed a non-existent wlan driver & non-existent switching wlan/bluetooth software.
What do I do, downgrade these drivers & softwares?
What is the risk if I don't downgrade?
Why Sony don't inform through vaio-link webpage of all these actions with their reasons?
Is usual this work style of Sony?
Thanks a lot.
Thalamus.
Champion
If you've installed the updates and everything is working ok, then I would leave your system as it is and not uninstall the new updates..
