Vaio pcg-Z1rsp wont power up
risitech
I am looking for replacement power button for Vaio pcg-z1rsp part no. 1-687-010-1
Tags (4)
Thalamus.
Champion
Hi risitech,
welcome to Questions & Answers..:smileyhappy:
Maybe worth contacting either one of Sony's authorised repairers or Vaio Support to see if they'll sell you the part.
To find contact details for Sony Vaio support..
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Then Click on the Out of Warranty tab to locate the nearest location.
Thalamus.
Champion
Hi risitech,
Then click Log-In
