vaio pro 13 SVP1321S1EBI ssd upgrade
atikoo
Sorry my bad English.
Where can I get to 256GB SSD?
Replacement little 128GB SSD
thank you.
Nobody-in-particular
Hi atikoo, if you want the same manufacturer then you should be able to check the make of your current SSD drive in Device Manager then google to see if they supply a 256GB drive, if not then I guess any SSD drive that is of the same dimension as the one currently fitted should be ok.
atikoo
HI.
Thanks.
Unfortunately I can not find
expensive and specialized 256GB
mine: SAMSUNG MZNTD128HAGM-00000
searching ebay expensive unfortunately.
Thanks.
