vaio problems using sony bravia as monitor
irb44
Is there anyone out there who can help me solve my interconnetion and display issues between my VGN-FZ21E and the Sony Bravia TV.
I simply cannot use the TV as a monitor. After connecting a standard 3m VGA cable I can either get the TV with full desktop while my PC only shows the wallpaper or the other way round. When using the Fn F7 to toggle I get an error message from the Vaio Event ? to tell me that I cannot perform this operation with my current display settings. It works succesfully ( toggling)with my standard Sony Desktop monitor but not the TV. I have spent hours trying to reorganise the settings on the display by changing the resolution all to no effect or a complaint from the TV that the PC signal level is insufficient.
What is required is the same display on both PC and TV monitor. Can anyone help???
Best regards
IRB
0 REPLIES 0
