I've been trying to create my recovery disks but I'm having problems.
The Application Recovery Disk was made no problem, but when I try to make a Sysyem Recovery Disk, it stalls at the same place every time (on 48%)
It then asks me to throw away the disk that wouldn't work, then re-start & then try all over again.
I've done this several times now, but it keeps on happening.
Anyone got any advice on this ?
Thanks.
I started to download the update for the MATSHITA UJ832 , but it then told me that it was not intended for my computer . . .
In that case I can only assume that you have a different optical drive fitted. To confirm this right click the drive in My Computer and select Properties > then have a look on the Hardware tab – you will see the manufacturer and model listed.
Rich, I just did an upgrade search on the properties page & it came back with details that it couldn't find a better drive update than the one that is there already.
Is there an e-mail address or a phone number for Sony that anyone knows ?
Thanks.
Hi spookie,
You can contact Vaio-Link either by phone, e-support or Fax just select the method of contact from the list here
