Hi everybody!!
I would like to restore my hard disk on my VAIO fs215s laptop but my VAIO rtecovery utility is corrupted. I 've not got the restoring CDs so Iwonder If i could download the VAIO RECOVERY UTILITY in order to reinstall the software. Where can i find the VAIO RECOVERY UTILITY or how could I restore my Hard disk without the utility or the cds?
Thanks for your helps!!!!!!!!
Cris
Hi Cris and welcome to Club Vaio.
You can order a set of recovery disks from support but they are expensive.
Your model has a hidden restore recovery partition which you should be able to access by tapping F10 during start-up (when you see the Vaio logo).
Be aware that the recovery process will format the C drive, so make a backup of any important data.
