Vaio Upgrade to Vista, can I install bundled software from XP?
alexcord
:thinking: Wondering if anybody can help me? I bought a Vaio VGN-FE11S last May with Windows XP MCE.
I have bought Vista Ultimate but would like to do a clean install. Is there any way that I can extract some of the pre-installed apps bundled with the the laptop eg. Adobe Premier elements, Acrobat elements?
Alex
4 REPLIES 4
Thalamus.
Champion
Hi Alex,
Welcome to Club Vaio. :slight_smile:
Have you created a se of recovery disc's, if so explore the your recovery disk do the application files have a .PAC files extension..?
If you have .pac files have a look on google for something called Kcap.exe...:smileywink:
alexcord
Thanks mate!!!! All working now with a clean Vista!! Really appreciate it!
Thalamus.
Champion
You're welcome alexcord.. :slight_smile:
Now may be a good idea to back-up your Vaio using something like Arconis true image
kee-lo_
It's kinda hit and miss to see if they work with Vista.
